Quote:
go to the wizard and select preset goblin raw 580(my values are taken from there and my sab goblin raw 580 is PERFECT)
Yes, I wrote it in my last post. Why do you repeat it?
Quote:
I'm having a doubt, what servos do you use for cyclic and tail?
Please take a look to post 4 (my 2nd post)
Quote:
the name of the servants?
I don't no what you mean.
Quote:
but you what a procedure you used to set 0 degrees of the blades?
I don't use a cheap and imprecise analog gauge. The first step is to level the swash plate with a level tool in the min., max. and middle position (thx spirit team. Great feature!)
and afterwards I assemble the head. The second step is to adjust the blades (which are correctly aligned along the longitudinal axis) with a leveled digital gauge.
