It is currently Fri 03. May 2024 21:06:44
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Wed 03. Aug 2022 8:52:03
If you dont proceed according what manufacturer is saying then it mean you are trying to be more clever then they are.
Then you can't be surprised something is not working perfectly.
Your smartphone is not used to control any aircraft :) There any difference will not cause any harm if it is more or less 10°. Also more precise apps are able to download calibration data from the internet for location obtained from GPS.
With drones, including from DJI you will be often prompted to do new calibration when changing location.
Manual has recommendations and all instructions for a very good purposes. Not for making things more complicated, but to make them working in the most possible circumstances.
Then there will be only few questions if people will do everything right.
PostPosted: Wed 03. Aug 2022 12:46:58
Dr.Fleming
you will be surprised how much can change the earth magnetic field by few km
if you look at charts showing isogonic lines following magnetic declination
btw magnetic field don't change only when you move
but also as the time go by
PostPosted: Wed 03. Aug 2022 16:27:12
Correct magnetic field's are everywhere, but the North, South, East, and West, as far
that I know , has not change in the last hundreds years ! :ugeek:
urgno wrote:
Dr.Fleming
PostPosted: Wed 03. Aug 2022 16:35:12
earth magnetic field is constantly moving
magnetic north and south pole make no exception
west and east are only a geographical convention
there are no west and east magnetic poles ;-)
PostPosted: Wed 03. Aug 2022 21:47:17
hello Tomas !
Calibration is always required and highly recommended as described in the manual.
With GeoLink v2 - when calibration process is running green light is ON and blue light is blinking during movement.
When it is finished, green light will be turned off while blue led will start to flash periodically.
Calibration itself is very same as with v1. But v1 had only one LED.
that is what I am going to do , Thanks for the detail info . your advice is priceless after all you designed the geolink . Other people who know more than you maybe they should design their own . :D
PostPosted: Thu 04. Aug 2022 9:17:40
HobbyWing ESC fan is affecting all sensors, including all Spirit units and other FBL units. For this reason we do not recommend to use it, especially if using Rescue and Stabilisation modes.
PostPosted: Thu 04. Aug 2022 9:18:47
Thread was locked as no new relevant information was added there and original problem was resolved.
Users browsing this forum: Google [Bot] and 20 guests
