Hi everybody,
I was looking through the logs collected by the Jeti DS24 from the Spirit Pro, which in turn collects the data from a Jive Pro and saw that the BEC Voltage measured by the Jeti receiver is different from the BEC Voltage measured by the Jive. The one from the Jeti is correct.
Heli on the bench.
File comment: Voltage graph
My config is as follows:
Jive Pro 80+
Spirit Pro collectic telemetry from the ESC throught the Spirit Kontronik 4 pin servo cable (not the new SAT one)
REX6 Jeti receiver on EXbus
Jeti DS24 logging the telemetry from the Spirit
This is another log capture with RPM visibile, heli on the ground with blades installed.
So both logs show the same behaviour.
I have installed the latest version for all the electronics:
Spirit Pro 3.2.2
Jive Pro 1.14
REX6 1.14
DS24 5.05
Any insight will be appreciated.
