It is currently Tue 21. May 2024 16:59:58
Klaus
Posted: Sun 07. Feb 2021 10:01:22 |
Tested following: New firmware 3.2.2 and old bin file -> same problems. Then I again installed new Jeti integration files -> same problems.
At last I assigned a bank switch in my Radio and everything in Jeti Integration works well now. I think new firmware 3.2.2 needs to assign a bank switch, otherwise Jeti Integration works strange.
Regards, Klaus
Posted: Sun 07. Feb 2021 20:03:59 |
We have tested with DS16 and latest firmware, Banks assigned and Banks unassigned. Result is, it is working just perfectly in our case with all latest files. Firmware 5.05 is working also well with DS12.
For this reason we would like to get your Spirit Settings file and we will load it to our units and retry.
Posted: Mon 08. Feb 2021 13:05:56 |
We have tested also with Manfred's settings file and again, everything is OK.
Do you think it would be possible to disconnect everything from the unit, except BEC and retry?
Klaus
Posted: Mon 08. Feb 2021 16:45:36 |
I also tried to disconnect the telemetry sensor (Kontronik Kolibri) but that makes no difference.
Attached the old 4ds file. In this setting also no channel is assigned for bank in the RS-unit. Also I could not see the headline like Bank 0, Bank 1, Bank 2 in the Jeti Integration menue.
In my new configuration with assigned bank switch and bank channel mapping everything works perfect. So no problem for me anymore.
Regards Klaus
Posted: Fri 12. Feb 2021 9:27:20 |
Could you please try to update to 3.2.2-r2 firmware version? It is available in the Spirit Settings from now. I hope this can help you.
Klaus
Posted: Fri 12. Feb 2021 18:00:05 |
Tested the r2 version of Firmware.
Now it also works fine with no bank channel mapping in the Spirit-RS unit.
Thanks and best regards Klaus
Posted: Fri 12. Feb 2021 18:01:59 |
Oh, perfect. So now everything is resolved?
Klaus
Posted: Fri 12. Feb 2021 18:18:34 |
Yes, everything resolved now. Thanks for your quick update.
Klaus
Werni
Posted: Tue 23. Feb 2021 9:15:23 |
Joined: Fri 03. Aug 2018 20:32:07 Posts: 9 Location: Germany
Hi everybody, is it recommended to update from 3.2.2 to 3.2.2-r2 firmware version for everybody? What are the improvements / changes? Best regards Werni
Users browsing this forum: No registered users and 39 guests |
