It is currently Fri 19. Apr 2024 19:29:40
Post new topic Reply to topic  [ 13 posts ]  Go to page 1, 2  Next
PostPosted: Thu 26. May 2022 20:02:50
On the channels dialog, there's only 6 available entries for functions to be set. Please increase this to 10.
At the moment, i'm using 4 for GeoLink, and 1 for rescue, and I use the last one for tuning.
With the release of spirit v3.4.0 firmware, it's possible to set stabilisation using functions, however there are not enough free F: slots to be of any use to me, which is a real shame as i'd like to enable rescue and stabilised flight modes from switches.
My radio has 16 channels (opentx/edgetx), I use 6 channels for control (T,A,E,R, gain, pitch), and would like to use the other 10 channels for functions.
Also, please consider implementing a different method for setting up features. In the radio, channel overrides are required to set up different features on switches, which just seems like a really bad way to program a radio.
To set up GeoLink, I needed to program 8 different channel-overrides just to allow RTH, pos hold and auto-land.
A mix system similar to "iNav" where a feature is assigned a channel, or channels + the channel position range, would (imho) be so much easier to program and maintain from a user perspective. Channel overrides would then not be required. Much less radio programming would be required, making it much easier to maintain.
It would also allow a single switch to enable multiple features at the same time, e.g. altitude limit + return to home, etc.
See an example here:
https://mrd-rc.uk/images/taranis/inav-5 ... -modes.png
PostPosted: Sun 03. Jul 2022 14:34:03
I fully understand and support this, because I have the same problem. Too less selection changes in spirit to get all the great GeoLink functions setup.
I'm using S-Bus too, so I have 16 channels and I can setup only 12 of them. 4 additional would be great for additional functions.
Best Regards
Bernhard
PostPosted: Sun 03. Jul 2022 15:06:11
Its really annoying that each function requires it's own channel. If functions could be assigned to channel number + channel microsec range, then functions would be unlimited even with a 8 ch radio.
PostPosted: Mon 04. Jul 2022 12:48:01
The other option described here with signal ranges assigned to function would be even also a great option. I have this for a sound module in use. In Betaflight it is also common to use signal ranges assigned to functions. This can be used for several categories in the Spirit:
- Geo-Link
- Spectrum Analysis
- Setup optimisations
- Stabi Modes
Steps can be -100%, -80%, -60%... 0%, 20%...100%
-100% = Off/Default
This makes it possible to have 10 functions per chanel.
PostPosted: Mon 04. Jul 2022 12:54:45
GeoLink is already using signal ranges for functions. We will consider to add this option. At the moment our aim is to simplify settings.
PostPosted: Mon 04. Jul 2022 13:40:21
That would be great.
Can you please increase the number of F functions asap as it's not possible to use all the features as there's not enough F functions to assign to.
PostPosted: Mon 17. Apr 2023 0:06:05
I've now run out of channels, so can only use a small number of the available features.
Will this be resolved soon?
I'm using 11 channels on my radio. It has 16. Spirit only allows 6 features to be programmed.
PostPosted: Wed 17. May 2023 11:52:49
I've used a setup like your inav in AccuRC it's very intuitive plus can set multiple functions per channel.
Sent from my LYA-L29 using Tapatalk
PostPosted: Sun 04. Feb 2024 2:05:41
Can I please ask for this again. You've added loads of new features to geolink and I can't use them because the software doesn't support more than 6 channels for functions.
I'd like to set up the following:
Switch 1
Rescue (acro)
Switch 2
Geo-fence + Alt limit
Switch 3
Alt hold + position hold
Switch 4
Stabilisation normal
Switch 5 (3-pos switch)
Return to Home (mid sw position)
Auto-landing (high sw position)
To do that, i'd need 8 function channels, the software only allows 6.
PostPosted: Mon 05. Feb 2024 18:37:52
I would also like to emphasize this wish.
In addition, please make the "anti-gravity" parameter adjustable via channel.
Konrad
