It is currently Thu 28. Mar 2024 9:38:06
[ 5 posts ] |
Peter Zimmer
Posted: Sun 08. Aug 2021 20:49:37 |
I like to operate a "lost beeper" at AUX2, but AUX2 supports the servo signal with 200 Hz. The frequency has been verified with an oscilloscop. Changing the frequency of the swash blade and tail servo to 50 Hz has no effect. A SAVOX servo works well on AUX2. The "lost beeper" works well with a servo tester at 50 Hz. I expect there is a bug in the firmware.
I use the Spirit 2 Firmware: Spirit Heli 3.3.1 Spectrum with 2 SATs Chanel 8 is configured for output on AUX2
swash23
Posted: Mon 09. Aug 2021 7:33:13 |
Joined: Fri 01. Nov 2019 13:32:19 Posts: 40 Location: Munich, Germany
Hello, did you try to change the throttle frequency in the "Governor / Throttle" menu?
Peter Zimmer
Posted: Mon 09. Aug 2021 18:10:57 |
Hello swash23,
in the throttle menu, the frequency is 60 Hz and the ESC works fine.
Peter
Peter Zimmer
Posted: Mon 09. Aug 2021 18:29:18 |
I just updated to 3.3.2, changed the throttle frequency Form 60 Hz to 200 Hz, saved it to the Spirit and changed it back to 60 Hz with saving to the Spirit. My problem that the beeper isn't working at AUX2, is still there.
Peter Zimmer
Posted: Sat 16. Oct 2021 11:22:26 |
I've made a interface circuit out of an Arduino Nano. Now it works.
[ 5 posts ] |
