It is currently Fri 19. Apr 2024 17:59:19
PostPosted: Thu 16. Jun 2022 0:08:13
Today I had a tail failure. I was sat in a stable hover at the time. A link snapped leaving the tail with no control. The heli spun round fast. I hit throttle hold, and auto'ed to the ground, only slightly bending the boom as I'm not a good flyer :D
So this got me thinking; if the tail is completely lost, e.g. there's no tail control at all, and the heli is inverted and moving,
can the spirit:
a) recover to skids down?
b) return to home? (if fitted with a geolink)
I know that expecting the spirit to recover from a mechanical failure is a bit above normal operation. I don't expect it will, but just wondered if it could recover without tail control.
No idea how you could ever test that.
PostPosted: Thu 16. Jun 2022 6:39:17
For full control of the movement of the heli you need all the controls to work. Otherwise it will never work.
PostPosted: Sat 16. Jul 2022 16:11:31
I have experienced this exact issue. I had the tail fail in flight, and by using rescue repeatedly while also "sort of auto rotation" down by turning off the motor I was able to "crash gently". The Gaui X3 was rotating but he cyclic was flat. If I was better at the auto-rotation I might not have broken the skids, but given what would have happened before having rescue this was a win.
PostPosted: Sat 16. Jul 2022 16:17:53
I also crashed the X3 :lol: Gotta watch that tail on the X3. The skids are really weak; attach them with zip ties instead of screws. They last longer.
