It is currently Sat 27. Apr 2024 8:11:56
Rcpassa
Posted: Sun 18. Oct 2015 20:53:49 |
It's a goblin 380....I thought I was running 13.5 +- for pitch and 10 for cyclic
Ktm250
Posted: Sun 18. Oct 2015 21:45:42 |
I have a goblin 380. The manual says max pitch is +- 12.5
mrnets
Posted: Sun 18. Oct 2015 22:09:13 |
12.5 ----> +1
And 2550 RPM is very low for a G 380, I use this RPM for my G 570. It's not enough for keep blades "right" when a high cyclic rate is applied. Maybe consider to use 3200 RPM or close.
Rcpassa
Posted: Mon 19. Oct 2015 0:08:19 |
Ok...how about cyclic pitch?
Alyon187
Posted: Thu 26. Nov 2015 0:23:21 |
It sounds like you were just running too much pitch. I just set my g380 up today and when I reduced cyclic ring to where it didnt bind I was at 10 cyclic at midstick and 12.5 collective pitch. This is w the kst215mg servos. The rest of my setup is setup within optimal range for the system as well.
What was your rescue pitch set at?
Mr.HillBilly
Posted: Thu 26. Nov 2015 6:30:44 |
On my G700 I have +-13 Collective and 11.5 on Cyclic. I have done a lot of rescues at 2050 HS. I am still chicken to try it from inverted at 2150 tho.
When I did my swash ring I am no where near the max I can get out of it, not sure on the 380 but on the classic head 700 I think I can get over 15 degs. cyclic before it even starts to bind at +-13 collective.
I am hoping the next version lets us slow the flip down. I have my roll rate at 12 in the Spirit software and it still flips a lot harder so I figure it is flipping as fast as it possibly can.
Users browsing this forum: No registered users and 66 guests |
