It is currently Wed 18. Sep 2024 3:21:38
PostPosted: Thu 01. Aug 2024 3:33:10
So I set up my gtr with my laptop. Always auto save my changes. I set up my yaw limits. Later I used my jeti ds12 to check and possibly change my limits in my Spirit in the jeti. The same limit numbers were displayed in the jeti software, but when I adjusted them, and pressed ok, they revert back to the limits set thru the computer. How do, or can I adjust and save thru my radio? I want to be able to change perimeters at the field if needed. Thanks in advance.
PostPosted: Thu 01. Aug 2024 11:51:44
have you closed the PC software before making adjustments with radio?
This can cause such problem.
