[SOLVED] Bank switching pitch problem https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5943 |
Page 2 of 2 |
Author: | Driveline651 [ Thu 01. Feb 2024 14:45:43 ] |
Post subject: | Re: Bank switching |
Solved : It turns out that the pitch limits were indeed different in bank 1 and 2 . I:E my pitch limit was 115 in bank 0 from the initial setup of the helicopter . When I looked , the bank limits for banks 1&2 were set to 64 . I moved them up to 115 to match bank0 and verify that it seems to work properly on the bench now . I hope to verify with a flight later today . Note: I did just setup a different spirit GT using a satellite rx instead of the 6 ch rx like on this unit . I do not recall having to check or adjust the pitch limit between banks using this setup method . The difference is with the sat rx I used channel 7 to activate bank switching and channel 8 to active the function Vs reassigning channel 5 to activate bank switching on the 6 ch rx Maybe I just got lucky on the first one . Thank you all for your help ! |
Author: | Driveline651 [ Fri 02. Feb 2024 0:55:21 ] |
Post subject: | Re: [SOLVED] Bank switching pitch problem |
I was able to fly it Today and it flies properly in all modes . Fix is confirmed. Thanks! |
Page 2 of 2 | All times are UTC + 1 hour |
