Nitro Engine temp sensor https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5830 |
Page 2 of 2 |
Author: | Mattes61 [ Sat 07. Oct 2023 21:00:53 ] |
Post subject: | Re: Nitro Engine temp sensor |
Hello ! The fact is that the FPort protocol is bidirectional, otherwise the integration would not work because sending and receiving data is necessary - The integration works via the antenna of the transmitter and receiver and via the bidirectional protocol - That's why it should be done adding the temperature sensor everything works as usual - you would have to re-explore the temperature sensor by re-reading the telemetry in the remote control, then you also know what it is called and program the corresponding warnings in the control, but I think you know that - Maybe Tomas has an additional idea what should be observed too - Regards |
Author: | ZeXx86 [ Mon 09. Oct 2023 16:24:21 ] |
Hello, as I said previously any telemetry sensor will not work with F.Port. This receiver has support only for F.Port 1 where telemetry sensors are not supported. You have to use older S.Port or F.BUS. But F.BUS is not supported by this receiver. |
Author: | ZAQ [ Tue 10. Oct 2023 12:44:15 ] |
ZeXx86 wrote: Hello, as I said previously any telemetry sensor will not work with F.Port. This receiver has support only for F.Port 1 where telemetry sensors are not supported. You have to use older S.Port or F.BUS. But F.BUS is not supported by this receiver. Ok, I think I finally got it right. I skipped the f.port 1 and f.port 2 part. One final suggestion if I may ask... what would be my best next option to get the engine temp reading on my TX16s, well except buying a Spirit GTR . Ditch the r-xsr and get another receiver? |
Page 2 of 2 | All times are UTC + 1 hour |
