It is currently Sat 21. Sep 2024 2:08:23
PostPosted: Tue 13. Sep 2022 16:03:19
Hi there,
I got everything working after long searches ;) and the telemetry data from my Kontronik Kolibri 140 ESC is transmitted through the Spirit GT to my FrSky receiver and Radiomaster TX. Everything but the consumed capacity. Is there a known problem, that this value is not transmitted? Using S.Port I get the value from the ESC direct to the RX, but I don‘t like to have two more cables and a y-connector.
I get RB1V, GAlt, Fuel/Vibration, RB2C and a lot more, but RB1C always stays at 0, although the TX shows, that it regularly receives a signal.
Any ideas?
Thanks,
Oliver
PostPosted: Tue 13. Sep 2022 18:17:32
have you tried it in the air or without blades on the bench?
PostPosted: Tue 13. Sep 2022 18:22:44
Without blades on the bench.
PostPosted: Tue 13. Sep 2022 18:27:27
Then please try it in the air, it will very likely work well.
PostPosted: Tue 13. Sep 2022 18:49:47
Thanks, will do that and report back.
PostPosted: Sun 02. Oct 2022 10:56:25
Works as you said - no problem at all, just on the bench.
Thanks for the help!
Solved!
Users browsing this forum: Bing [Bot] and 160 guests
