Governor GTR https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5363 |
Page 1 of 1 |
Author: | dgfgbg [ Sat 27. Aug 2022 7:54:32 ] |
Post subject: | Governor GTR |
Hello, I use GTR 3.4.0 with Kraken Nitro. The RPM sensor is a Spektrum SPMA9569 connected on Ext and powered by Spektrum port. The telemetrie RPM work fine. The curves motor on radio and Diagnostic are exactly the same. The log show Governor engaged, but I have no regulation, when I engage governor. I get allways the max RPM. I played with Governor response, holding performance and holding limit but nothing change. When I modify the max RPM, the value change correctly. What can be wrong ? Thanks for help |
Author: | Scott H [ Sat 27. Aug 2022 11:10:55 ] |
Post subject: | Re: Governor GTR |
I found this behavior too, if I had the Max Head Speed in the gov tab set too high. What number did you put in that box? |
Author: | dgfgbg [ Sat 27. Aug 2022 11:16:55 ] |
Hi, First I tried 2 400, then 2 200, and I see that the limit is respected, but curves like 60% or 70% doesn't decrease the Rpm. |
Author: | Scott H [ Sat 27. Aug 2022 11:25:35 ] |
Try 2000 max head speed and see if that helps. Also high gov response settings can do this too I believe. |
Author: | dgfgbg [ Sat 27. Aug 2022 11:38:40 ] |
Already done, without success. |
Author: | Scott H [ Sat 27. Aug 2022 11:51:39 ] |
I found changing settings in the Spirit can be a tricky thing. Some settings can be changed live and it's not needed to hit the save button. Some things can be changed and the save button works. On the Max RPM settings. I found the Spirit needed to be power cycled for that setting to 'take'. That was my experience, If you were changing Max Head Speed's in the radio and flying - those settings likely didn't have an effect. |
Author: | dgfgbg [ Sun 28. Aug 2022 8:23:30 ] |
Ok, thanks for comments. I will try next week and give youu feedback. PS my bank 0 is Gov disabled, with TC under 50%. Are you in the same process ? Denis Envoyé de mon SM-G960F en utilisant Tapatalk |
Author: | dgfgbg [ Sun 28. Aug 2022 19:32:45 ] |
Good evening, I tried this afternoon with the bank 0 and Governor enabled, and it's work now. In this bank the TC is under 50%, and when I switch to bank 1 and 2 with Governor, all parameters are active correctly. I confirm that when I change a parameter in a bank, it's active without restart the GTR. Thanks for asssitance. Denis. |
Author: | ZeXx86 [ Sun 28. Aug 2022 19:37:05 ] |
Hello, all parameters except Receiver type, ESC telemetry and GeoLink support (enabled/disabled) will be changed and active immediately as soon as they are changed even without pressing the Save button. So nearly all parameters will take effect with no power cycle. |
Author: | dgfgbg [ Mon 29. Aug 2022 8:35:31 ] |
Hi, Is it correct, that Governor doesn't work, if bank 0 is disabled ? Denis. |
