It is currently Fri 29. Mar 2024 16:05:53
[ 7 posts ] |
mb-1953
Posted: Fri 29. Jul 2022 20:33:40 |
I just replaced a spirit 2 with a spirit gt. The firmware is 3.4.1, bind plug in pit/elev/ port for dsmx. The satellites blink but every time the bind fails. I've tried a variety of satellites and new wires. any help would be appreciated.
Posted: Sat 30. Jul 2022 15:33:32 |
Joined: Wed 21. Dec 2016 15:13:38 Posts: 481 Location: Germany
Hello mb-1953, sometimes the distance from the transmitter to the sattelites are to short, then binding fails - try an wider distance - If this doesn't work, do you have an spektrum receiver with satellite-Ports ? Try to bind the satellites with the receiver with the respective modelmemory - Push in some battery 4-Cells (NiMh) in the receiver for power supply and try to bind with the transmitter - If they are binded you can put the satellites into the spirit and bindig in spirit isn't necessary any more - The bindig is only a thing between receiver and transmitter and not a thing of spirit...
Regards Matthias
Posted: Sat 30. Jul 2022 15:40:05 |
Please make sure to select correct frame rate in the radio. If it is for example DX6 then it can bind only at 22ms.
mb-1953
Posted: Sun 31. Jul 2022 12:29:25 |
I tried various distances, won't bind. The frame rate is 22ms. I have over 20 helicopters and all with spirit and have never had a problem binding before. The radio is an IX12. Any other suggestions?
Posted: Mon 01. Aug 2022 8:02:24 |
As above said, it has nothing to do with the Spirit FBL, try it in another way with an receiver as also above said - Maybe you have an problem with your IX12 ?
Posted: Mon 01. Aug 2022 8:24:06 |
In this case you have to bind with two bind plugs. One at SYS port and one at ELE/PIT/AIL. This will initiate 22ms binding process. iX require 22ms frame rate in order that all channels are working. So please try two binds plugs. I hope this will help.
mb-1953
Posted: Mon 01. Aug 2022 11:17:15 |
I bound the satellites to an new Spirit GT, and transferred them to the one with the issue. Now connected. Thanks for the help.
[ 7 posts ] |
Users browsing this forum: Bing [Bot], gerry and 1 guest |
