It is currently Mon 13. May 2024 21:36:27
[ 4 posts ] |
gerry
Posted: Thu 21. Jul 2022 13:55:46 |
Joined: Fri 26. Aug 2016 6:51:10 Posts: 218 Location: Austria
Hello Tomas, I would like to adjust the cyclic head sensitivity with a rotary potentiometer from the transmitter for the three banks. I have selected the "P: Cyclic sensitivity" function in the channel display and channel 9. I have created a transmitter with this potentiometer on the jeti transmitter and put this encoder on channel 9 when assigning the servo. In the channel selection in the Spirit menu of the transmitter, I can clearly see that when the potentiometer is activated, channel 9 reacts between 20-100, in the middle it has exactly 60, as is currently set in the Sensors tab. But when I turn the potentiometer it changes the value in the sensor display does not change and remains at 60. What am I doing wrong or am I misunderstanding this P:cyclic sensitivity function? Or is it not intended that the cyclic head sensitivity can be set in this way?
Please help.
_________________ Greetings from Gernot
Posted: Thu 21. Jul 2022 14:14:47 |
it is enough to close the software. When software is open the value will not change.
gerry
Posted: Thu 21. Jul 2022 14:25:23 |
Hello Thomas, thanks for the message. Is it also the case with the setting software on the transmitter that you have to close it and only see the changed value when you re-enter?
Posted: Thu 21. Jul 2022 14:33:27 |
Yes, it is same.
[ 4 posts ] |
Users browsing this forum: No registered users and 51 guests |
