Hello! I copied the new BIN files to the Jeti. These appear to have resolved the interface errors. See screenshots below. Receiver is recognized, firmware version is displayed correctly, no errors in the integration. I ran through the setup wizard to check everything. All seems good. Rescue by function is good, telemetry is available. Then tried to bench test the functionality of the Heli.
I found one possible problem: -
- When in the setup wizard I can set the collective and cyclic ranges as expected. On my RAW 580 I have set and measured collective 13 degrees and cyclic 12.8 degrees. All normal.
- With the Heli on the bench, in a normal flight mode (with motor off), the actual cyclic range is limited to about +/- 5 degrees for both aileron and elevator. Measured with pitch gauge.
- With the Heli on the bench, when I am in Spirit -> Limits menu (not via setup wizard), changing the cyclic limit setting has no effect. The actual cyclic range is limited to about +/- 5 degrees regardless of the cyclic range setting.
Is this normal behavior please? It seems very strange. Please let me know. Thanks!
