Geolink position + altitude hold https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5268 |
Page 2 of 3 |
Author: | 10x [ Fri 08. Jul 2022 17:57:03 ] |
Post subject: | Re: Geolink position + altitude hold |
"Second, if you clued the connector in full on the spirit, and therefore the Baro not get air inside, than you are in trouble." You still have the LED hole... |
Author: | jjuk [ Fri 08. Jul 2022 18:48:15 ] |
It's a geolink module. The led doesn't have a hole. I've swapped the 2 modules I have over and will test later on a heli that holds well and the 500x that doesn't. I'll also try without the geolink case lid fitted incase it is too sealed to work. |
Author: | jjuk [ Sun 10. Jul 2022 12:19:02 ] |
Swapping the geolink modules didn't make any difference so I can only assume the geolink is working correctly and the problem is software related (or my spirit2 is faulty). The heli flies fine manually. My setting file is attached to an earlier post. (post #5). Can someone at Spirit please propose a solution. Thanks. |
Author: | jjuk [ Sat 16. Jul 2022 11:33:35 ] |
@ZeXx86 Any thoughts on what is wrong here? |
Author: | jjuk [ Sun 17. Jul 2022 23:05:04 ] |
Here's a video of the problem. Clearly, that's not holding the position. https://clipchamp.com/watch/8nerYkbyfvb |
Author: | ZeXx86 [ Mon 18. Jul 2022 7:38:30 ] |
Hello, the problem could happen if servo neutral point is not mechanically in the center. You can check if it is good by enabling Servos / Subtrim (tuning) menu. Then all 4 servos should move exactly to the middle of their travel range. Servo arm should be at 90° - as precise as possible. At the same time there should be 0° between main blades. If you are unsure then you can take a photo of the swashplate + servos when menu is enabled and I will check it. |
Author: | jjuk [ Wed 20. Jul 2022 0:30:20 ] |
I have checked this. When subtrim check box is enabled, the 3 cyclic servo arms are at 90 degrees, and both blades are at 0 degrees of pitch. I am using servo travel correction to ensure that the swash is level throughout the full cyclic range. It has been mentioned in this thread that this may be an issue. I'm assuming that the auto-flying modes (rth, pos and alt hold, stabi, rescue) all control the servos AFTER any travel correction has been applied and taken into consideration in the calculations, correct? |
Author: | Dr.Fleming [ Wed 20. Jul 2022 10:58:43 ] |
Looks to much gain on Vertical gain ! jjuk wrote: Here's a video of the problem. Clearly, that's not holding the position.
Author: | jjuk [ Wed 20. Jul 2022 11:36:19 ] |
Its set to 20%. I can't change it any lower. |
Author: | Dr.Fleming [ Wed 20. Jul 2022 18:34:51 ] |
Go trough the "SETUP WIZARD" and check your setup, and in case correction it, there is no other. jjuk wrote: Its set to 20%. I can't change it any lower.
Page 2 of 3 | All times are UTC + 1 hour |
