It is currently Thu 28. Mar 2024 23:18:36
PostPosted: Thu 02. Jun 2022 14:47:03
FW 3.4 Channel Direct asignation not work with Futaba Sbus, and missing Anty gravity mode on channel list. :cry:
PostPosted: Thu 02. Jun 2022 14:50:00
it works with all radios, there is no difference for unit what radio or receiver you are using until you have enough channels.
It mean that something is configured incorrectly. We will finish our manual to make it more clear in following days.
You can attach your configuration so I can check it.
PostPosted: Thu 02. Jun 2022 15:32:13
Thanks for quick answer, also I see on the channel windows,the green moves when I activate the Rescue normal,
but nothing happen, I try disconnecting the Stabi, but the same. But as usually works wit Stabi Funktion :roll:
PostPosted: Thu 02. Jun 2022 16:01:44
You have to set Selected by Channel in the Stabi tab as Function.
PostPosted: Sat 04. Jun 2022 9:32:46
Was problem resolved by setting Function to Selected by Channel?
