[SOLVED] No luck getting new firmware installed https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=5225 |
Page 1 of 1 |
Author: | petemz [ Sat 28. May 2022 21:30:44 ] |
Post subject: | [SOLVED] No luck getting new firmware installed |
Like a dog chasing its tail with this new firmware. It installs and indicates success. When I go to restart the software, I am back to square one. A window comes up saying the new firmware is not compatible with the current firmware and to update. Helicopter is flying fine on 3.3.3 so maybe I don't need to fix something that is working OK. |
Author: | ZeXx86 [ Sat 28. May 2022 21:33:56 ] |
Post subject: | Re: No luck getting new firmware installed |
Hello, you have to also install Spirit Settings software 3.4.0. Otherwise it will say always this message, because firmware is already likely at 3.4.0, while software is likely 3.3.3. |
Author: | 10x [ Sat 28. May 2022 21:34:16 ] |
Have you installed the new software? |
Author: | petemz [ Sat 28. May 2022 22:20:05 ] |
No, I have not installed the new software. Was not aware there was any new software. Will go and do that and report back. More than likely that is what needs to be done. Thank you both for the quick replys. |
Author: | petemz [ Sat 28. May 2022 22:38:47 ] |
New software installed and firmware updated perfectly first time. Thanks for your help gentlemen. |
