It is currently Sun 05. May 2024 20:04:02
[ 5 posts ] |
rotorhead51
Posted: Sat 11. Jun 2022 1:08:31 |
Hi Tomas I am hoping you can help me with a strange issue after updating to 3.4.0, I was at the field today and connected with my phone to make changes to my nitro gov., noticing that I didn't have my radio on, I turned on my radio to check my diagnostic page and lost connection after turning on my radio. when I got home I tried using my PC and USB connector and it does not recognize my Spirit GT anymore (with my radio turned on). strange thing is, if I power up my GT unit without my radio on it recognizes the GT and I can make changes. both software and GT unit is showing 3.4.0. I tried re-flashing firmware and even recovery mode but it will not connect when my radio is on! no problem yesterday when I initially flashed the update thru my PC, I immediately tried connecting with my android phone and it worked perfectly, with the radio on. any thoughts as to what I should do next? radio is Futaba 18SZ with R7008SB receiver.
Posted: Sat 11. Jun 2022 10:33:59 |
have you enabled Kontronik Jive Pro, Kosmik telemetry?
rotorhead51
Posted: Sat 11. Jun 2022 12:28:21 |
Yes, telemetry has been selected I wanted to check my headspeed as I was flying.
Posted: Sat 11. Jun 2022 13:33:04 |
Very likely you wanted to select TelMe telemetry option. Because Kontronik Jive Pro & Kosmik is old and deprecated option. And behavior you are describing is correct actually. See instruction when you select it or in the guide.
rotorhead51
Posted: Sat 11. Jun 2022 13:40:32 |
Good to know, thank you for the quick response Tomas. I will make the change. BTW, my nitro gov. is starting to work the way I want, after lowering the holding limit % and increasing the main gain the head speed is holding just fine. not sure if I would get this kind of customer service from any other manufacturer, your customer service is second to none!
[ 5 posts ] |
Users browsing this forum: No registered users and 30 guests |
