It is currently Fri 19. Apr 2024 2:00:46
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri 26. Nov 2021 14:02:23
Mr.Tomas,
Please see the attached picture of Spirit Pro FC and advice which is the SAT1 and SAT2.
Regards,
Amal
PostPosted: Fri 26. Nov 2021 14:35:51
A is primary and b is secondary...
http://manual.spirit-system.com/index.php?title=Wiring
PostPosted: Fri 26. Nov 2021 14:44:39
http://manual.spirit-system.com/images/ ... ellite.png
PostPosted: Fri 26. Nov 2021 14:47:04
Thank you.. :D
PostPosted: Fri 26. Nov 2021 17:51:54
amal , the cable is easy to make
I had to make long cables for my goblins because the esc is at the front and Spirit at the back
These work fine but have genuine Hobbywing esc
I still need to test the Align esc with the latest firmware
PostPosted: Mon 29. Nov 2021 5:59:10
Mr.Andy and Mr.Tomas,
I manage to make the UNI wire and I can confirm it is working. Without UNI wire + SBus2 connection + ECS RPM wire connected I can see motor RPM. Also, with UNI wire + SBus2 connection and without ESC RPM wire I can see motor RPM, battery voltage etc. I wasn't able to see motor Amp even though the blades were installed but spool up on the ground. I guess the bird needs to lift off.
So, basically telemetry feature is working for me with the right connections.
Mr.Tomas, would you be kind enough to tell me the JST connector series of SAT1/2 ports. I had to remove one connector from one of my Geolink extension cables and I need to purchase a replacement socket.
By the way, below are some photos of my bird. Please feel free to comment :D
Regards,
Amal
PostPosted: Mon 29. Nov 2021 9:46:29
Very nice!
Connector is JST ZHR-3.
Yes, model must be in the air to see current draw and capacity.
Users browsing this forum: Google [Bot] and 53 guests
