It is currently Thu 18. Apr 2024 15:59:48
[ 3 posts ] |
gerry
Posted: Sun 16. May 2021 8:06:57 |
Joined: Fri 26. Aug 2016 6:51:10 Posts: 218 Location: Austria
Hello Tomas. I still have the problem that the motor jerks when it is switched on before it starts up slowly, I've tried a lot of settings, I just can't get it away, the only setting where it works properly is when I turn it on Set "very slow", but then the motor simply takes too long to reach the set speed. I have currently set it to "slow" where the motor jerks again, the run-up time would be fine! I have the following hard goods: Spirit RS (Gov Mode) YGE 205 HVT controller Scorpion 4525 engine What could be the mistake?
_________________ Greetings from Gernot
Posted: Thu 20. May 2021 11:46:48 |
it could be needed to set different mode in the ESC settings. So that Initial Power will be lowered.
You can use Spoolup Rampup to minimize this effect. If there is delay, you have to increase the value. Smooth spoolup require configuration on both sides, with YGE it should be possible. Have you changed YGE parameters in some way?
Settings can be different than when using YGE Governor.
gerry
Posted: Thu 20. May 2021 19:59:20 |
Hello tomas, I set the starting current to min 1 amp and max to 3 amps on the Yge. The test was a little better but still a jolt. If I further reduce the starting current at max to 2 amps or 1 amp, the motor will run no longer going on
[ 3 posts ] |
Users browsing this forum: Bing [Bot] and 44 guests |
