I am adding my yesterdays experience, to this "solved" thread, because I have already explained my components here, I hope this is ok.
I had about 10 flight (just hoverings, because of beginner
) with the mentioned setup and no problems. Still with the "RPM sensor data are to noisy" in the log, but no abnormalities.
Yesterday i changed my RPMs for the first time from 2200 to about 2500 (through flight mode, Normal to Idle1) took off and suddenly had a RPM collapse to 1370 RPM, as you can see in the Jeti Log.
"RPM sensor data are to noisy" was the only entry in the spirit log, I change the RPM through flight modes (Heli Setup) an constant curve:
Anybody an idea?
