Spektrum ar8010t https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=4486 |
Page 2 of 2 |
Author: | ZeXx86 [ Fri 22. Jan 2021 21:26:44 ] |
Post subject: | Re: Spektrum ar8010t |
It is better to use AR8010T in any case, but not with PWM, but SRXL connection. This is safer and more reliable. One Spektrum satellite without receiver might be enough, but I recommend 2 satellites. Or AR8010T. |
Author: | Pete678 [ Sat 23. Jan 2021 11:11:58 ] |
ZeXx86 wrote: It is better to use AR8010T in any case, but not with PWM, but SRXL connection. This is safer and more reliable. One Spektrum satellite without receiver might be enough, but I recommend 2 satellites. Or AR8010T. so it will be safe to run srxl1 on the unit and have full integration? I'm planning on using all 3 satellite ports on the ar8010t with the newer satellites from spektrum, as i don't want to mix old with new. Thanks, Pete |
Author: | ZeXx86 [ Sun 24. Jan 2021 12:13:49 ] |
It will be perfectly safe. But with this receiver there is no integration possibility. It has SRXL v1 which does not support integration. Please take a look here: http://manual.spirit-system.com/index.p ... ntegration You will need receiver such as (if you want integration/telemetry support): SPM4649T (discontinued), SPM4650, SPM4651, SPM9747, AR6610T |
Author: | Pete678 [ Sun 24. Jan 2021 13:14:02 ] |
So when you say integration you mean telemetry? I'm not fussed on telemetry to be honest. So can i use the single cable into srxl for rf purposes only and it work? That is all i want to use it for. Thanks, Pete |
Author: | ZeXx86 [ Sun 24. Jan 2021 13:19:38 ] |
No, by integration I mean possibility to configure Spirit unit directly from your radio. And also telemetry transmission. But AR8010T is more than enough for flying. |
Author: | Pete678 [ Sun 24. Jan 2021 14:04:16 ] |
Right, hopefully my last question on this!! What is the best way to wire the rx to the spirit 2? Thanks |
Author: | Pete678 [ Sun 24. Jan 2021 17:25:50 ] |
Scratch that last comment. I'm going to be using the srxl for connecting to the spirit. I didn't want to just dismiss this rx as it has some good reviews. Plus i didn't fancy dropping another £100+ for new receiver and sat with program cable!. Although it's not the new srxl2 protocol it's still a very good bet in my mind, as having the 2 antennas coming out of the rx and the 3 satellites that will be connected, i think my rf signal will be covered. All axis's and grey spots will be covered by the sats. Thanks for all the help |
Page 2 of 2 | All times are UTC + 1 hour |
