[SOLVED] No cyclic to left side after 2 min flt in Stab Koax https://www.spirit-system.com/phpBB3/viewtopic.php?f=20&t=2892 |
Page 2 of 2 |
Author: | ZeXx86 [ Thu 18. Oct 2018 7:19:42 ] |
Post subject: | Re: Issue: No cyclic to left side after 2 min flt in Stab Ko |
Ah, that is great. So maybe just by disconnecting the fan it will all work well. Could you please disconnect it for a try? It should handle also 3D flight without the fan on your model. HobbyWing fans are unfortunately creating ultrasound that is disturbing the sensors a lot. For this reason disconnecting it it could be all solved. |
Author: | tabbie [ Thu 18. Oct 2018 9:27:04 ] |
I have removed the fan. Trying again this evening. |
Author: | tabbie [ Sat 20. Oct 2018 6:46:43 ] |
I have flown the heli yesterday, perfect weather. I changed the following before the flight, removal of the ESC fan hobbywing 100A platinum, I have changed the GEOLINK to a closer position about 10cm away from tailservo. I have wrapped the GEOLINK cable with aluminium foil from a chocolade bar and grounded the foil to the tail boom. The issue is gone, everything is good now. (solved) |
Author: | enied [ Sat 20. Oct 2018 7:34:31 ] |
tabbie wrote: I have flown the heli yesterday, perfect weather. I changed the following before the flight, removal of the ESC fan hobbywing 100A platinum, I have changed the GEOLINK to a closer position about 10cm away from tailservo. I have wrapped the GEOLINK cable with aluminium foil from a chocolade bar and grounded the foil to the tail boom. The issue is gone, everything is good now. (solved) I did buy a Sunon MC30100V2-A99 fan for my hobbywing 100A V3 platinum and use it. No problems caused by the fan at all. BR Eugen |
Author: | ZeXx86 [ Sun 21. Oct 2018 19:21:44 ] |
That is great! Thank you very much for the message! |
Page 2 of 2 | All times are UTC + 1 hour |
