I don't know the Heli-Jive exactly because I have no one -
But I have an suggestion for you - If you have setted the correct Motorpoles and the gear ratio in the Heli-Jive you can maybe manipulate the RPM-Telemetry-Sensor in the transmitter, test it with changeing the multiplier, if its possible or you can change the gear ratio in the telemetry settings in Spirit Software -
I can't think of anything else to say -
You can only try it - I hope this helps -
