It is currently Fri 19. Apr 2024 18:21:39
Post new topic Reply to topic  [ 14 posts ]  Go to page Previous  1, 2
PostPosted: Thu 27. Dec 2018 18:28:34
Ok, so workarounds are:
1) use OTX file, or
2) have channels in this order in the radio: AETR, Gyro, Pitch, or
3) after remapping channels, save settings and restart the wizard from the beginning (probably works, not tested).
Option 1 is no solution for me, as I prefer to set-up everything on my own and know exactly what is configured there. But hopefully 2 and 3 will work. I wish I recall this thread next time I configure Spirit.
PostPosted: Sat 29. Dec 2018 0:43:01
Maybe this topic can be helpful : viewtopic.php?t=2753
Envoyé de mon CMR-W09 en utilisant Tapatalk
PostPosted: Sun 02. Aug 2020 8:15:42
The provided OTX file has pitch and nick mixed up.
PostPosted: Thu 06. May 2021 19:14:42
1) use OTX file, or
I'm just setting up a brand new Spirit unit, and I can confirm solution 3 works.
I will remember this in future. But with my previous 2 units it was 2h wasted time trying to figure out why stuff doesn't work. So I think it would be good to make a fix for other users, so they don't get stuck there.
The problem is, that the wizard only works fine if you don't change the layout (channel assignment). If layout needs to be changed, min / max / center values seem to be garbage... And new layout needs to be saved to unit first, and unit + wizard restarted.
Users browsing this forum: No registered users and 35 guests
