It is currently Mon 01. Jun 2020 5:07:03
PostPosted: Tue 19. May 2020 22:16:46
I know spirit supports tail rotors, but has anyone hooked it up to a 150s? It looks like the tail motor is feeding into the main esc and then outputting just one lead (plus an rpm signal) I was fiddling around with it last night and could not get the motor to arm although the cyclic servos did respond.
Has anyone gotten one of these working and could compare notes?
PostPosted: Wed 20. May 2020 15:56:25
For 150S - You have to look at 2 parameters for this Dual-ESC. To be more precise - to get this ESC armed.
In General - Throttle settings
AND
the parameters "Limits" Rudder End Points.
There you can find the secrets you are searching for.
Which parameters are set there ?
PostPosted: Sun 24. May 2020 1:52:22
I've tried uSpirit on 150s and it works fine
(Currently tail in unstable, need to find correct settings)
Separate one lead is for tail motor signal
and Lower Rudder end point should be low enough for tail esc to arm
I hooked Tail ESC to separate receiver and recalibrate throttle range
Because I couldn't get right value for High Rudder end point (range was too low)
(I hope this improves unstable tail but I haven't test yet)
PostPosted: Thu 28. May 2020 4:47:05
Awesome, thanks guys!
I’ll play around with this and see if I can get it working. If so I’ll share my findings here
Users browsing this forum: Google [Bot] and 1 guest
