SRXL2 Technology https://www.spirit-system.com/phpBB3/viewtopic.php?f=21&t=3640 |
Page 3 of 6 |
Author: | 10x [ Thu 23. Jan 2020 18:31:52 ] |
Post subject: | Re: SRXL2 Technology |
Hello Tomas Thanks for this, will try at the weekend... |
Author: | 10x [ Sat 25. Jan 2020 23:20:15 ] |
Hello Tomas I see from the new software that there now is a srlx2 in the receiver section. If i have the spm4651t and 2 sats do i now pick srlx2 in the menu. Before with the spm4649t i had to pick dsmx... Regards Adrian... |
Author: | ZeXx86 [ Sun 26. Jan 2020 8:46:56 ] |
Hello, SPM4649T does not support SRXL2 so everything is same here. |
Author: | 10x [ Sun 26. Jan 2020 19:02:52 ] |
Hello Tomas I want to put in a SPM4651t with 2 dsmx sats. If i choose SRLX2 for the SPM4651T, will the 2 dmsx sats still work? this is on a Spirit Pro... Regards Adrian |
Author: | ZeXx86 [ Sun 26. Jan 2020 19:28:07 ] |
No, DSM2/X satellites and SRXL2 receiver will not work together. You have to get SRXL2 receiver and SRXL2 satellite. |
Author: | 10x [ Sun 26. Jan 2020 19:41:00 ] |
ZeXx86 wrote: No, DSM2/X satellites and SRXL2 receiver will not work together. You have to get SRXL2 receiver and SRXL2 satellite. Thanks for this Tomas..As there are no SRXL2 sats available at the moment i will wait untill normal DSMX sats can be used... Regards Adrian |
Author: | tfmcnellist [ Tue 28. Jan 2020 1:23:26 ] |
Post subject: | Re: SRXL2 Sats |
The SRXL2 remote receiver (SAT) link below. Available late March No external antenna wires! https://www.horizonhobby.com/dsmx-srxl2 ... er-spm9747 Will these 4wire sats use an adapter to work with the sat port or use an adapter to connect to the main connector pins? |
Author: | ZeXx86 [ Tue 28. Jan 2020 8:51:20 ] |
These receivers can't be used with satellite ports. There will be adapter which will be connected at the AIL/RUD port. This adapter will be available for sale likely this week in our eshop. |
Author: | ragge1 [ Tue 28. Jan 2020 10:08:44 ] |
Can the 4651T be compined with DSMX sat ? , as this is possible with brain2 and even the new Spektrum FBL unit Skickat från min SM-G950F via Tapatalk |
Author: | tfmcnellist [ Wed 29. Jan 2020 23:06:52 ] |
Will the sRLX2 receiver and SRLX2 satellites be connected to the same port through the Spektrum Multi adapter? |
Page 3 of 6 | All times are UTC + 1 hour |
