ZeXx86 wrote:
It is enough to click at three buttons in total.
First select file, then add the file as attachment and then confirm the post.
Anyway if there is some problem you have to see some error. Otherwise you just missing to click at the buttons.
Hello all, Yes - I was doing something WRONG... Will see if I figured it out
I added step-2 of the wizard. My elevator connector is at the front, but when I pick the model to Trex-600, it shows the swashplate with CH-2 at the back, why?
I reset the unnit to factory, I have NO reversing on the Tx, I have no reversing on the unit.
All my stick directions are correct, including the tail / rudder.
The only thing I can't get is the 6 degrees, I can get as close as 8.2 degrees. Does this indicate that my swashplate is sitting too high?
